Change colors of a pre-painted model
That’s valid, I missed you didn’t want to achieve your stated goal, only to complain it wasn’t possible, while ignoring it was possible, just nit where you expect it shoukd be located.
That is not the answer.
A bug is an unknown or expected outcome running contrary to the expectations of the code.
This is a feature that doesn’t exist.
Bugs are not the omission of something.
It baffles me that people can be fired up enough to say “why can’t I do this here” to be told “you can, just not ‘there’” and decide “if I can’t do it where I expected it, I refuse to do it all.”
Good luck with your lack of interest in resolving the problem (solutions clearly stated by me months back) and your seeming enjoyment of being annoyed.
  1. Go download the nightly version of orcaslicer from github
  2. Open your 3mf with it.
  3. Use orcaslicer’s painting tool’s “replace color” feature
  4. Save, close orcaslicer, optionally uninstall
  5. Open your 3mf with bambustudio
Unfortunately, as I have come to learn. It isn’t where he wants it to be, so he will just focus on being annoyed.
It can be done in bambu Studio, just not where he wants it done.
He says he isn’t interested then.
Suggesting he might use two slicers is unlikely to remove the “not where he wants it” annoyance shown.
Takes two clicks. Already explained.
Oh dear…
Since the functionality is present but not where you want it, a feature request tag (if you genuinely want that feature) or highlighting a rant would have been appropriate.
Good luck
I think I am missing something here, it seems everyone is explaining how to change the main filament color but not the painted portion? In Malcs example above he changed the main color of the frog but he never showed how to change the painted eyes.
Eh, this is an old thread and a new feature, figured I’d give a current-era way of accomplishing the task. I cant be arsed to keep track of the dates features came out vs forum posts made lol :smiley:
I tried your way, it works thank you very much for that.
I think you missed something important.
My example was an example of how to change any colours, I demonstrated changing the red
I demonstrated changing one colour “orange” to “red”, that happened to be the frog’s body, but I didn’t change the model’s body, I changed the colour selected while printing.
I apologise (:winking_face_with_tongue:) for only writing a detailed step-by-step guide with images, I assumed the very clear instructions of choose the colour you don’t want and select the colour you do want would allow people the leap of faith to make subsequent changes.
As the eyes contain the colours: white, yellow and black, you repeat the highly detailed steps I provided and swap the white for something else, the yellow for something else and the black k for something else. That assumes you wanted to change all three.
In case anyone says “I didn’t want to change all three”, just change the ones you wish to change in the identical way I detailed them here and every other post I have written this.
You could select (in my example) every colour to be white, that works to, you don’t have to have every colour unique.
My point was not directed at you, just the futility I felt out attempting to help someone that didn’t want help despite asking a question.
Yes but you didnt change the yellow or black in the eyes which are the painted part of the model
Was this directed at me?
It didn’t appear until after I responded above.
No I was refering to Bullocks method of opening the file in Oraca
Are you suggesting that swapping white to pink, yellow to green and black to purple will not print the model with eyes of pink, green and purple?
Because it does.
I have tried and cant figure it out.
In this example I want to change one of the yellow stripes to blue and one of the green circles to blue.
That is a different problem to the one we were discussing before you joined in.
For this, you use the paint tools as they are designed.
This has nothing to do with the question of swapping one filament for another. This is you needing to use the paint tool after making sure you have the colours required in the filament chooser first (top left of your screenshot). You have a blue in the selection, if that matches your desire, you don’t have to add a new one.
You then select the colour you wish to use, select the tool that works best (I like the one that matches edges) and touch the area you wish to change, rotating the model until you have all sides.
Repeat for the second change.
Your need is the exact use case for the paint tool.
Had you built the model yourself (I am assuming not), you should have built each section as a different STL object and imported as a single object, then you would select each part individually assigning their colour. This is the fastest, easiest and most precise method.
Thank you!!!
I have been using the other suggestions here about just changing the colour of filament on the left. But it turns out when you have 21 plates of various colors and painting, it sure messes stuff up.
I am sure Bambu will come up with the same setting in Studio sometime soon. Hint! Hint!
