So I tried to print an item using Handy. The model was uploaded to use PETG but I wanted to use PLA. Is there a way to change that? I didn’t see a way on a quick look.
Mike
Mike
No it does not seem so. I had to add 4 profiles for a model for PLA, PETG, ASA and ABS.
Well, that would be unfortunate.
I may be wrong, but it was my understanding that you pick the material type, then it is sliced in the cloud using settings for that material.
Tap Prepare to Print.
Select your printer model (P1P, P1S, X1c, etc).
Choose from the available Profiles, tap to highlight.
Choose your printer and plate.
Use the Filament dropdown to choose the filament.
If you have your own calibrated filament presets, slide the button over, select the type of
filament and then your preset.
I did all that. But, in your example how do you print it in PLA? I was only able to change colors.
Mike
Actually, I played around some more and think I found it.
Thanks
So what was your solution? Could you please share it with us?
Very easy:
Step 1:
Add new filaments (Any colours)
Step2: Delete old filaments and keep new filaments.
Step3: Go on your text, objects right click and click on ‘‘change filament
Tada… After that, it works ![]()
