First AMS use an printed the 3d printed led lamp
My issue, there is a real small gap line between blue and yellow, see attachment.
He advised to do this:
preferences (ctrl+P) → activate developer settings → Quality →Advanced → First Layer Flow Ratio: 1.04
I activated dev settings but only see Initial layer flow ratio. Thats the same??
Will this close the gap? Any other ideas?
Thanks!
3DTech
January 17, 2024, 9:25pm
2
YES = It will flow more filament on first layer only it will help
This setting will override the global setting for flowrate in filament settings?
Thanks!
3DTech
January 17, 2024, 10:07pm
4
Only the first layer will get changed with more flow; all other layers above it will be your master flow ratio setting.
kaleen
October 5, 2025, 12:33pm
5
But how this modifier works. If my flow ratio in filament settings is set to 0.95 and I will change the Advance first layer flow ratio to 1.05, will I get 0.95*1.05, or maybe will I just get 1.05?
iChris
October 17, 2025, 11:27pm
6
The wiki states that the flow ration is calculated by entered value. Meaning you will get 0.95*1,05 and not 1.05.
The actual flow ratio is calculated by multiplying the original flow ratio by this factor.
