hello all which fans are good to replace those of the bambulab x1c? I am looking for fans to replace the fans of the bambulab because I find them noisy and for me they are not good. which fans are compatible and good?
There aren’t any known replacements. The sad fact of life is that fans that move enough air, and aren’t huge, tend to be noisy. Quiet fans move less air and are less effective.
hello i heard about the noctua but i don’t know which one is right for the x1c, there are many noctua fans as models and i don’t know which one is right
The MB fan on the X1C is sitting in an open space, double sided taped to the frame. Its not even screwed down and is doing very little to move air as its current placement is not how its use is intended. There should be a blower fan and it should be mounted by screw and bracket… To top it off, its a cheap fan with a high failure rate. The P1P doesnt even have a MB fan installed at all. There are oddities of this printer that make no sense its just laziness.
@Syndicate_X what do you think, where should the extra fan be put?
For the MC board fan, the proper Noctua part is NF-A4x10 5V PWM. But I would recommend instead buying the fan Bambu sells in their store, which should by now be the better version. With the Noctua fan you would have to splice the connectors.
@holmes4 how long have they updated the fans? I have had the printer for a month … are my fans already updated?
All I know is that they said upgraded fans would be in the online store at the end of January. I have no clue when they phased these into production. If your MC board fan is not making a loud racket, then don’t worry about it.
after 8 days of owning the X1C i can say Printers delivered in end of jan have still the issue, my fan started to get noisy yesterday, im now in contact with the support
