Hello everyone, I’m new here in the forum. I wanted to ask if I can change the gcode so that the bed temperature can drop after the 30th layer.
You can of course add the gcode for if layer 31 change temp to X
Just select the layer via the slider in the preview tab and right click to then select add custom gcode.
Thank you for your quick response. Works perfect.
