Change STL from PLA to PLA-CF
Hi,
I have limited colours of PLA and a greater variety of PLA-CF.
If I download an STL designed for PLA, are there specific changes that can be made to print in PLA-CF instead?
If so, could anyone advise an application to use or give advice on this please?
The material you use does not depend on an stl. An stl is just a fileformat that defines the x, y and z coördinates. Maybe you mean a 3MF file? That’s an stl file but with some production parameters. (a 3D Manufacturing File)
In both cases you can of course change your settings to whatever you want.
Simply import your file into the slicer, and change the parameters of the filament you use. In case your file is .stl. If instead it is a .3mf file you will simply have to enter your printer, your printing profile and the profile of the material you intend to use to print that file.
