I’m having problems with a model that I downloaded. For some reason, there is a small gap in the bottle in the inside corners almost halfway up the bottle. Changing the gap setting in Studio to fill the gap also causes problems with the text on the bottle, as it also wants to fill the gap between the letters. I don’t want to print this model in 2 halves and glue them together.
Welcome to the forum.
If you upload the .3mf file for this model it will be much easier to help you solve your issue.
Coca Cola Bottle 6pack.3mf (2.6 MB)
Here is the project I’ve been using. The problem is below the red section. Layers 346 to layer 377. If it weren’t visible in the final print, I wouldn’t be as concerned.
Try changing these two settings in the Quality tab
Wall Generator = Arachne
Wall Transitioning Threshold Angle = 59
