Is it possible to change the order of the parameters in the parametric model maker? I imported a file from Fusion and the default sort is the order in which they are created. Unfortunately, I kept adding more and more parameters as the design evolved and now they’re not grouped together in a way that makes sense.
Anyone have any tips on how they can be reordered, either in Fusion or the Parametric Model Maker on Makerworld?
I was looking for a Fusion f3d issue I was having and saw your question. I think the only way you can reorder it is by removing all of your items from favorites. Then add them in the order you want. I had that issue a long time ago and that was the only way i got it to work.
I can’t confirm that the order of the favorites affects the order of the parameters in MakerWorld. I can reorder them by favoriting them, but they aren’t saved in that order when I click “OK.”
I exported the parameters and then had AI sort them.
When you import them into a new Fusion project, they’re in the correct order. Depending on how complex your model is, you might have to redesign it,
but AI also created a Python script for me that allowed me to swap out the parameters. Unfortunately, I can’t tell you how to do that, though.
