Choosing PTEG vs PLA spool on AMS Lite
Total noob here, but I’ve successfully done multiple prints without issue and am still having a boneheaded issue with choosing which filament I want to use for a model, and in the current case being unable to select the PTEG filament on my AMS Lite. I suspect it’s a fundamental misunderstanding of either the Prepare screen or the Device Screen.
Currently, the PETG is loaded on spool 4, and Basmbu Studio sees it there, it’s even loaded. But when I go to Print Plate, in the spot where I would normally want to select that spool, it’s grayed out and theres a message saying “only AMS slots containing the same material can be selected.” Same as what? Is there something in the Prepare screen I’m supposed to be setting up? I don’t see where I’d set different bed or nozzle temps for just this project (or nozzle). The model is downloaded directly from MW and I’m using the designer’s settings and they recommended PETG, so it would seen like I should just be able to select that slot and go. What gives? Thanks for your help.
Screenshot 2024-11-05 at 11.07.49 AM
Screenshot 2024-11-05 at 11.07.23 AM
Screenshot 2024-11-05 at 11.06.16 AM
It means the model was sliced for a PLA not PETG. You need to reslice the model for PETG.
In Bambu Studio, click on the model and press “4”. This will change the model to use the Bambu PETG you have loaded, Reslice the model and transfer it to the printer. Alternatively you can right click on the model and select “Change Filament”
No freaking way. I knew it had to be stupid. Thank you. Printing now.
