So my prints were failing in the beginning which I initially thought was a nozzle clog. So after replacing the hotend I figured it was good to go. Nope. Problem still persists. Not sure where the clog could be if it isn’t in the hot end. Any help would be appreciated
Can you tell us a little bit more? Do you use ams or not? What temperature are you printing with? Does it clog straight away when you start printing?
I had a similar clog while using the gold silk PLA. What seemed like a golden metal thread was stuck in the extruder just enough to cause problems without stopping all flow.
