I updated to the latest firmware and I’m experiencing very slow downloads from the cloud when printing. Maybe the servers are running slow at the moment.
Same situation too.
Since update very slow download from Cloud to printer. In addition, I have to re-enter the access code to the camera every time the printer is switched off. This is different after each printer start. That wasn’t the case before and is extremely annoying. I hope, the update for the update is coming very soon!
Yup, horrendous. It doesn’t affect the X1C though.
Annoying, as we run nightshifts and just don’t need this kind of issue at 2:00AM
I had the same issue with the access code, but logging off from the printer (via the printer screen) and re-binding it via the app fixed that issue for me.
Thanks for your response i will test it out.
I Made my Test.
Logged out from App and Windows Program, restart Printer and Apps and then insert the new Access Code. After Printing shutting down the Printer and disconnected him from the Power.
After that new Start.
A new Access Code was generated. ![]()
I’m also having seeing issue, about an hour to unzip the 3mf on some p1p’s with the latest update.
Other printers with the same firmware and 3mf file, or similar size 3mf file, don’t take the same amount of time.
Did you log out via the printer screen?
The printer itself needs to be logged out, and then you use the APP to “re-bind” the printer to your account.
I believe this rebinding attaches the new printer access code to your account.
Same with me.
Since the last firmware update I see extremly long download times, often interruptions. This wasn´t the case before
Today i installed firmware 01.02.02.00 and everthing looks good. Download is fast like on the begin. Connecting the camera separat is not nessecary when after firmware update in new rebound was made.
For me its good no. Let’s print ! ![]()
Unfortunately, the X1C also has this problem
long download times and sd card degredation messages. (on 4 different cards including new ones.)
Very long downloads this past week in Europe, both before and after updating the firmware.
Is it happening again for others than me now?
facing this same issue for both my p1s. tried everything including setting up new routers but it does not work. the download speeds are very slow and will timeout eventually.
