Cloud printing not working
I’ve seen all the other posts so I know it’s not an issue with my printer, but I don’t see any other way to make them notice and fix the problem than to flood them with issue reports.
I can barely get a print started, it takes me 10 minutes of sending a print and resending it a couple of times because the printer didn’t start printing before I get it to work.
Lan only mode does not work for whatever reason, I can’t connect to my printer from Bambu Studio.
It’s not a wifi issue, my printer has 4/5 bars of connection strength and it has been printing flawlessly for the past 1.5 months. Issues started yesterday and they make it barely possible to print anything.
Exactly the same issue for me
I just had to try 3 times to get LAN Only to work. Bambu Studio kept freezing when it asks you to enter the pass code. 3rd try it decided to accept it so I am printing OK (for now…). What is concerning me is the lack of response from Bambu, which does not auger well for the future.
Lan wasn’t working for me for a while. What I found that worked was logging out of my account and connecting through lan-only mode
every time there’s an update, it’s a mess! The cloud makes things even more unstable. I can’t do it with my phone, let alone my PC.
A solution from the developers?
Logging out and printing in offline works. Thanks.
Lan while logged in worked for me for a while but stopped. They need to fix their cloud ■■■■
Having same issue on 14 May 2024.
Same issue. Bambu says they fixed it but it still won’t connect for me.
Cloud printing seems down at the minute. hopefully just a temporary thing.
Had the issue with latest update .67
Downgraded to .66 and it works again.
To all below; up again now.
same here i was able to print a hedgehog and that is it. i can only print from the SD card that every printer gets.
same issue as of 5/16/24
Cloud print getting stuck at 30% and fails to send. I cannot put it into only land mode either for some reason…
Having Same Issue…April 2025
Same problems, but Logout and login resolve problem.
