Bonjour,
in search of this
Filaments translucides en C/M/Y/White
Bonjour,
in search of this
Hi! A lot of people search for specific high-translucency white filaments mainly because traditional CMYW generators make the final print look dull, muddy, or grayish.
I recently built a free CMYW lithophane generator that reworks the 4-color blending algorithm to eliminate that washed-out gray cast directly from the model generation. It lets you achieve vibrant, clear colors with much better light transmission using standard filaments, so you don’t have to hunt for exotic translucent materials.
You can try running your photo through it here: https://my-gpu-node.top
Hope this saves you some hassle and filament tuning!
not for traditional lithophane,
really for lithophane figurine or buste
Ah, got it! That makes total sense. For hollow 3D figurines and busts with internal LEDs, filament translucency and wall diffusion definitely matter a lot.
In that case, you might want to check out Bambu Lab PLA Translucent (White), or semi-translucent PLA from Polymaker / eSun. They diffuse internal light really nicely across varying wall thicknesses. Good luck with the bust project!
