Color brim
hello all, how do you change the color of the brim? if I’m printing with ams on the same layer it makes me black brim and white body how do I make it white?
how to set the color of the brim if i print with multiple colors?
I want to know how to set the color to the brim
Topic already mentioned 2 months ago, with similar title
it doesn’t work as you say… i put it on the first one but it doesn’t work.
following order bs/ams does not work
Last comment in the linked topic, i picked earlier
Curious, never tried it but I would imagine the support filament setting could play a part. What do you guys have the support filament set to?
I had the same issue. But I did find a solution. Remember, the brim will be the color of the first color printed. So we just need to have the desired color print first. To do that, click on “Plate 1” which will bring up your “Plate Settings.” Then, you should see “First layer filament sequence.” Toggle it from “Auto” to “Customize”. From there, you can choose the order of the filaments. You can also change the filament sequence of other layers if you want.
