Colour bleed with new printer
I have only just started with 3d printing and this is my 1st post.
The first multicolour print of Winnie the Pooh. I have noticed it has got bleeding of black, from the eyes and nose, into my yellow. The filaments are all PLA and the yellow is from the aux extruder and the black is from the main. Does anybody know why this is happening.
There is no problem with the red and the yellow on the same model
Are you using both nozzles? As in one for the black and one for the yellow.
If you are using a single nozzle, increase the flushing multiplier.
If you are using both nozzles, it would be easier to look at the 3mf to see where it is bleeding.
Pictures are the best way to troubleshoot around here if you can add some.
Also, as this is not directly related to the conversation at hand in this topic, @JonRaymond fan you move it to a new one.
I am using both nozzles.
Can’t seem to post image in my post
I’ll try to move it as soon as
Its fine, you need to post and read some more to raise your trust level and make new posts.
Thats why I asked Jon to move it for you.
Moved and I increased @GCH trust level.
@GCH
Share your .3mf and some pictures when you get the time
How does your prime tower look?
My first guess would be the flush multiplier.
I’ve noticed it has been defaulting to 0.7 (at least for me) on the latest Bambu Slicer versions. So you might want to increase it to 1.0
It’s also filament dependent, I’m now printing a multicolor print, using mostly Bambu filaments, and 1 non-Bambu one. All the filaments print perfectly fine. Except for the non-Bambu one, which shows bleeding by every filament that’s printed on the same layer with it. So I suppose some filaments just more prone to bleeding, and need bigger purge amounts.
Is it possible that the yellow filament is not completely opaque? Then, at spots, where the yellow PLA is very thin, you can see through some black PLA that is behind.
Thank you for the responses. I have since looked closely to the images of the original design and noticed, when zoomed in it had the same problem.
I wish I’d looked more closely before wasting the filament but we learn from our mistakes, hopefully.
