Connected P1S Can't send print file
Hello.
I have been trying to print for a few hours without any luck. My printer is showing as connected to the Bambu Studio and I can calibrate and control via the PC. When I slice, all works but when I go to “Print Plate” I get the usual “Send Print File” box up with Timelapse and Bed Levelling, the SEND button is not activating. I’ve tried numerous times with different models and the same issue. There are no fault codes, I have formatted the SD card. Both PC and Printer connected to the Wifi.
Any ideas?
Thanks in advance.
Welcome to the community.
What do you mean by the “Send button is not activating”? Is it greyed-out or it just won’t react when you click it. A screengrab would go a long way in allow us to help you.
Do you mean this window?
Screenshot 2025-04-18 at 19.44.50
Common reasons the send button will not enable
  • Do you have a printer selected in the printer selector?
  • Do you have “AMS enabled” (because you have one), but the matched filament (from swatches) hasn’t matched anything?
Hi, the same thing happes to me. I can´t upload the file to the cloud and I get error 56.
Hi and thanks for responding.
No AMS used.
Got it. The PLA Filament setting was set to see AMS. Changed it to external and everything rosy.
