Connecting P1S to unprotected Wifi
We recently purchased a P1S for my work. While the printer has been working fine when using a SD card in a traditonal way, I have not been able to connect to the required wifi network to use all the wifi enabled features. The required network is one that is not password protected. Its one the is used for other devices in the plant that need wifi but can’t connect with a user name and password. When trying to connect to wifi, it requires a password and won’t let you skip or bypass that step. I’ve searched for a resolution but haven’t been able to find any here, in the wiki, or subreddit. Has anyone found a way to connect to a password-less or unprotected wifi network?
Hi!
Have you tried setting up the WiFi directly on the SD Card as described here:
I couldn’t try it out myself, but maybe you can give it a shot with leaving the password in the file blank. It’s worth giving a shot.
From what I have read, it still needs a password.
From what I’ve seen/read, it always requires you to use a password. But trying this is worth a shot.
