I’m a little confused how to connect it. I’ve read that it’s better to have the filament run through the filament buffer, but I also see Y splitters after the filament buffer. With the A1 I had both AMS HT units through a filament buffer.
What would be the correct way to connect 2 AMS HT’s to the X2D?
You don’t want the smoke colored 4-1… you want the off-white colored one. I run 2 AMS 2 Pro and 2 AMS HT. The Pros have one 4-1 that goes to the Filament Track Switch and the HTs have their own 4-1 that goes into the other port on the FTS.
Thanks for the help everyone. I ended up ordering the correct 4 in 1 but unfortunately the shipment got sent back to Bambulab. Because I had to leave the country I decided to search for something on Makerworld. Found this: The Smoothy - Y Splitter Connector - Free 3D Print Model - MakerWorld
Still had a few pass through connectors lying around so that solved it for me.
