It’s times like this that you really wish it had an ethernet connection.
If you’re on any Netgear router, like a Nighthawk, Orbi, etc, UNchecking the “Enabled 20/40 MHz Coexistence” box worked for me.
Thank You Steve! This worked with Asus router too.
Having trouble with your personal hotspot disconnecting on your iPhone? Don’t worry, it’s a fairly common issue. Here are a few things you can try to fix it:-
First, check your battery:- Make sure your iPhone has enough battery. A low battery can sometimes cause the personal hotspot to disconnect.
Next, try restarting your iPhone:- A simple restart can often resolve these kinds of glitches. Just press and hold the side button and one of the volume buttons until the power off slider appears, then swipe to power off. Wait a few seconds, then turn it back on.
Finally, try resetting your network settings:- This can sometimes help resolve issues with personal hotspot connections. Go to Settings > General > Reset > Reset Network Settings. This will delete all your Wi-Fi networks and cellular settings, so you’ll need to set them up again.
Thanks a lot Steve.
Thank you, I figured this was the issue and was trying to figure this out in the admin settings without success. But googling your suggestion led me to an app (offical) which allowed me to split the bands. Works great now!
Nice. Glad it worked for you.
I found out, that it only support 2.4Ghz , but it does not support channel 13.
To make sure it will connect, try 2.4Ghz at channel 1 or 6. This solved my issue.
Hey there, it’s super frustrating when your Wi-Fi button on your iPhone is all greyed out, right? Feels like you’re cut off from the world! Here’s the deal, there are a few things that could be causing this.
First off, it’s always worth a shot to restart your phone. Sometimes a simple reboot can clear up minor software glitches.
If that doesn’t do the trick, try toggling Airplane Mode on and off. This can sometimes reset the Wi-Fi connection.
If you’re still having trouble, you might want to check for any software updates. Outdated software can sometimes cause compatibility issues.
As a last resort, you could try resetting your network settings. This will erase all your saved Wi-Fi passwords and Bluetooth connections, so make sure you have those handy!
Thanks so much. That advice fixed my connect problem!
Glad I could help. New printer? If so, enjoy. Your mind is about to be blown.
Welcome to the forum
Hello
I also have problems here with a Bambulab X1C.
The printer connects to my router, but it won’t connect to the Internet.
I have already tried several things:
For the connection to the internet I use a Netgear nighthawk M1.
I hope someone can offer a solution for this?
Not sure this forum will let me resurrect such an old thread, but for anyone seriously struggling despite having all the right settings, this fixed it.
Hours and hours of troubleshooting and my network just never showed up in the list or said I had the wrong password if it did. Changed it form channel 8 (auto configure) to channel 6 and it instantly connected. The setting should be available on even the most basic routers. This was for Ubiquity btw, and my printer has been connected for MONTH and randomly decided to drop (first time). I’ll keep this in mind in case it reconfigures itself!
Xarik - thank you SOOOOO much. My connection just suddenly dropped after 1000’s of print hours. Nothing I did worked as it wouldn’t accept my password for wifi at 2.4 ghz. I called my internet service provider and asked them what channel my 2.4 ghz was on and they said it was on an auto-channel. I asked them to specifically move it to channel 6 and ■■■■.. my password was accepted. Again, you are a life saver. Thank you.
I’m glad that worked, but there is nothing magical about channel 6 except that it had less interference than whatever channel you were using before. Routers set for auto-channel selection should change automatically, but they do sometimes fail to update if another network begins using a nearby channel. Rebooting the router should force it to look for a better choice.
One of the many wifi analyzer phone apps will probably show channel 6 (or 5 or 7) being used by a neighbor’s wifi. The app can also show which channels are not being used nearby if you have your router password and wish to set the channel manually.
