Constant buffer jams solved
Ok, this kinda pissed me off. I kept getting jams and finally removed the buffer and circuit board. The buffer magnet was installed UPSIDE DOWN from the factory. No wonder. Glad to get it solved, but this wasted quite a lot of my time and caused me hours of frustration and failed prints.
The magnet likely wasn’t flipped from factory, if it was the printer would never have worked from day one.
It’s more likely that it flipped in the slot at some point. A few users have reported the exact same phenomenon, on printers that were previously working properly.
Anyone who has ever disassembled a buffer and seen its internal layout knows that the filament-presence sensor magnet cannot possibly flip over on its own. There is simply no room for such a maneuver: it is positioned within narrow guides and held in place by a spring.
I think it’s more possible than you may think - when the magnet is flipped, it binds against the filament and pretty much makes full retraction of filament impossible. If it were installed wrong from factory then the printer would never have been able to pull back filament from day one.
This exact issue has been raised before, others on this board are also of the belief this has happened. I think under exactly the right circumstances - high friction filaments and high chamber temp, perhaps, the filament is grippy enough and the plastic becomes compliant enough that magnet is able to rotate against the spring. Could also be related to the PTFE tube pulling on the buffer outlet if the toolhead is at the extreme front-left of the heatbed.
I struggle to come up with an alternate explanation.
Have you ever completely disassembled and reassembled a buffer yourself—removing the magnets, sliders, springs, and so on?
I cannot imagine any scenario in which a magnet, held between narrow guides on both sides, could rotate. Temperature is not a factor here; 65–70 degrees Celsius would have no effect on the plastic used for the buffer—it is certainly not PLA. I see no point in arguing further, but as someone who has studied the design of the buffer inside and out, I cannot believe that a flat magnet—provided it was installed correctly in the first place—could spontaneously rotate in its housing.
So I went to the support docs and confirmed it was clearly installed upside down. Once I corrected it, it worked fine. Its very constrained and I simply see no way for it to rotate in place. I say it’s clearly a manufacturing error. If it could possibly flip in place, then it’s worse - a design error that will need a design change to correct. I’ve only used PLA, ABS and TPU for AMS and its gotten stuck multiple times, but most of the time, I could just poke it with filament to get the filament to pass, so clearly the problem has been there all along, I just only hit it intermittently. Regardless, this is a product and not user error. I like the printer, no regrets, I just wish I had figured this out earlier.
