Cool and Hight Temperature Build Plates
Question is, can you put a hight temperature sheet on a cool plate or vis-versa? Another words are the plates the same and the sheets are what is different?
Yes, you can. The high temp plate, if you buy it from the bambu store, is just an engineering plate with a high temp sticker on one side. The cool plate is also just an engineering plate with a cool temp sticker on one side.
