Hey guys, need some help here. I have an A1 Mini at a remote location. I created a project to print on that. Now, to see what the print at the remote print might look like, I want to print it on my local X1C. When I load the project and switch it to use the X1C, everything goes well. Bed resizes to the X1C bed, and it even slices it successfully. When I click print I get a message that says “The selected printer is incompatible with the chosen printer presets.” How do I fix this? If I knew what presets it is referring to I could probably fix it. I’d hate to have to recreate the project from scratch for the X1C as the print is 5 stacked objects with different settings for each object.
When you send the job to the printer, there is a printer drop-down box in the middle of the “Send print job to” screen, make sure that one is also set to the X1C.
Argh! I was doing that but I must’ve gotten the printers confused. Last night I renamed them so that I know which is which. I must’ve been trying to send the job to the A1 Mini after I sliced it for the X1C. Thanks for the help!
