Crooked plate
hi I saw that some people said that the plate of the bamboo lab and crooked is not straight and I noticed that mine is also a little crooked, help me understand
Is it normal that the plate is a little crooked?
what is the buzz about this? I am very interested in understanding this problem well
Do you mean:
a) re-aligning the plate after routine removal for detaching printed objects or turning it over to use the print surface on the other side of the same plate?
b) correctly aligning a new build surface when attaching a new one to replace a worn surface (held to the plate by adhesive)?
c) getting help with a build plate that doesn’t seem to contact the magnetic build plate support at every point on its surface?
d) something else?
I’m talking about the crooked printing plan.
the press plate bends is not straight
If you’re referring to warped beds, then you can follow along in this thread:
