Hey guys, anyone understand how to load you custom profiles into the AMS setting?
Under the device tab in the slicer i go to edit my filament using the ams unit and i cant find my profiles that i have setup already?
It simple shows Generic or different brands not my custom/calibrated filaments?
New to the AMS, i figured i would just hit the edit icon and add my filament to the correct slot?
In the prepare window click on the cog wheel for the filament settings.
A window will open where you find all default filament and where you can click to add custom ones.
If you only set filaments using the AMS you only change default but not your own filaments.
Make sure that you have the correct printer model set in your slicer because the custom profiles will only show up under the model they had been saved with.
(Ignore missing AMS i currently have it unplugged) But still even in the external spool none of this will let me select my filament in the AMS section?
Seem to have found a partial fix for this, if i go into calibration, manage results i can add filament their and it then allows me to select it in the AMS section however it doesn’t allow you to adjust your flowrate unless you calibrate it every time?
