Hallo ,
in der neuesten Bambu Studio version ist es ja möglich Custom Filament Presets zu erstellen.
Nur hab ich das Problem das ich diese im AMS für meinen P1S nicht auswählen bzw diese erst garnicht erscheinen.
Bei meinem A1 funktioniert das wiederum einwandfrei.
Hat jemand das selbe Problem ?
Gibt es da eine Lösung oder ist das eine Funktion die dem P1S nicht gewährt wird…?
Hello ,
in the latest Bambu Studio version it is possible to create custom filament presets.
But I have the problem that I can’t select them in the AMS for my P1S or they don’t appear at all.
With my A1 it works perfectly.
Does anyone have the same problem?
Is there a solution or is this a function that is not granted to the P1S…?
In practice, you don’t really need to copy your presets to the printer, because those presets are useful only for slicing your model. But as an owner of X1C, I’m a bit disappointed, that my top of the line printer is being left behind and doesn’t have features, which were added to cheaper models.
Normally, I don’t need it, but I often load projects, and this also loads the AMS config. I must correct it manually when I don’t have the same filaments in the AMS. At this point, it would be nice to simply click sync, and all my loaded filaments in the AMS will correctly show up.
Hello
I’m new here
I have been using Hatchbox PLA filament in my old Wanhao D6
I have a lot of spool still
I’d like to know if someone has a setup for P hatchbox using a P1S printer
