Hi everyone, I’ve printed a custom nozzle wiper and I have noticed that just before and after the first layer inspection the print head is going to a location that is actually hitting the new wiper. Not really hurting anything but it would be nice if I could make it stop about half an inch to the left. Any idea where that position GCode is located so I could modify? I’m afraid it may actually be in the first layer scan code which I don’t think I have access to…?
Should also mention this is the new wiper mod I have been using… hands down the best one I have tried and I have tried many. It’s working wonders for removing the PETG-CF build up when used with custom code to wipe every layer (I actually wipe more than once).
Thank you Kungpaoshizi!!!
Here’s the code I use in the “Layer change G-code” section found in the machine settings under “Machine G-code”: It will work with a traditional or smooth timelapse.
; layer num/total_layer_count: {layer_num+1}/[total_layer_count]
M622.1 S1 ; for prev firware, default turned on
M1002 judge_flag timelapse_record_flag
M622 J1
{if timelapse_type == 0} ; timelapse without wipe tower
G92 E0
G1 E-[retraction_length] F1800
G17
G2 Z{layer_z + 0.4} I0.86 J0.86 P1 F20000 ; spiral lift a little
G1 X65 Y245 F20000 ; move to safe pos
G17
G2 Z{layer_z} I0.86 J0.86 P1 F20000
G1 Y265 F3000
M400 P300
M971 S11 C10 O0
G92 E0
G1 E[retraction_length] F300
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 Y255 F20000
{elsif timelapse_type == 1} ; timelapse with wipe tower
G92 E0
G17
G17
G1 Y265 F3000
M400 P300
M971 S11 C10 O0
G92 E0
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 Y255 F20000
{endif}
M623
; update layer progress
M73 L{layer_num+1}
M991 S0 P{layer_num} ;notify layer change
