Hi, I have a large print I would like to do with items 25 in diameter and 240mm long. I would like to put a custom support between the items at around 120 mm to make the print more stable as the print goes higher. The support must just be between the 5 parts at the height f 120mm. Can this be done and if yes please head me in the right direction.
Can you not design the supports into your model? May be easier.
That makes sense I could insert a part modifier cylinder between the parts and cut them of once done. Thanks made me think a bit ![]()
