Customers or influencers?
这是拓竹在中国的微信公众号上发布的一篇文章。这句话是通过机器翻译的,我的英语不好请理解。
This is an article published by Tuozhu on China’s WeChat official account. This sentence was translated by machine, my English is not good, please understand.
这是适用于 Bambu Lab A1 3D 打印机的官方热床电缆保护器。 ?
如上 ?
Zhè shì shìyòng yú Bambu Lab A1 3D dǎyìnjī de guānfāng rè chuáng diànlǎn bǎohù qì. ?
Rúshàng?
This is an Official Heatbed Cable Protector for the Bambu Lab A1 3D printer. ?
as above ?
From the blog
To a very small portion of A1 printers, excessive bending caused by “external force” leads to damage to the cable at the root. This damage might not immediately cause the cable to fail, but it will make the cable more susceptible to fatigue and damage in later use. Although the “fuse on the heat bed” will prevent the bed from overheating, and the “fuse on the power supply” will prevent any short circuits from developing into any meltdown, this damage will affect the reading of the temperature and may cause power loss or even “short circuits”. We think it is a serious threat to the safety that we should address.
极少部分A1打印机,由于外力过度弯曲,导致电缆根部损坏。这种损坏可能不会立即导致电缆失效,但会使电缆在以后的使用中更容易疲劳和损坏。虽然热床上的保险丝可以防止热床过热,电源上的保险丝可以防止任何短路发展为熔断,但这种损坏会影响温度的读数,并可能导致断电甚至短路。我们认为这是对我们应该解决的安全的严重威胁。
Jí shǎo bùfèn A1 dǎyìnjī, yóuyú wàilì guòdù wānqū, dǎozhì diànlǎn gēnbù sǔnhuài. Zhè zhǒng sǔnhuài kěnéng bù huì lìjí dǎozhì diànlǎn shīxiào, dàn huì shǐ diànlǎn zài yǐhòu de shǐyòng zhōng gèng róngyì píláo hé sǔnhuài. Suīrán rè chuángshàng de bǎoxiǎnsī kěyǐ fángzhǐ rè chuáng guòrè, diànyuán shàng de bǎoxiǎnsī kěyǐ fángzhǐ rènhé duǎnlù fāzhǎn wèi róngduàn, dàn zhè zhǒng sǔnhuài huì yǐngxiǎng wēndù de dúshù, bìng kěnéng dǎozhì duàn diàn shènzhì duǎnlù. Wǒmen rènwéi zhè shì duì wǒmen yīnggāi jiějué de ānquán de yánzhòng wēixié.
这种保护器在我看来是没有用处的,官方也不认为这是长久有效的保护手段。这种保护器会导致线缆的弯折程度变得更为剧烈(当平台移动到最前面的时候)
In my opinion, this type of protector is useless, and the authorities do not consider it a long-term effective means of protection. This type of protector will cause the bending degree of the cable to become more severe (when the platform moves to the front)
我在BamBu Handy APP中提交了热床线问题的工单,BamBu官方回复我说它们将彻底优化热床设计,并在2-3个月后寄出新的热床。
它们认为凡是热床线的弯折处出现褶皱的都属于故障产品。
它们给出的解决办法是寄热床自行更换,或者将A1寄回去官方换机,或者是退货退款
I submitted a work order for the hot bed line issue in the BamBu Handy app, and BamBu officially replied that they will thoroughly optimize the hot bed design and send out a new hot bed in 2-3 months.
They believe that any wrinkling at the bend of the hot bed line is a faulty product.
Their solution is to replace the heating bed by oneself, or send A1 back to the official replacement, or return it for a refund
like this
The bend radius was never the problem, it getting pinched was.
To be honest the problem isnt really prevented by this part, the way to prevent the problem is to not pinch the cable against something in the first place.
换机或者更换热床都需要等待2-3个月。我个人建议如果需要使用A1,如果有足够动手能力,则要求BamBu 的新热床测试好后将配件寄给你自行更换,这样也可以为其节约运输成本(从中国到您那里的邮费很贵)
在得到新热床之前,我不是很推荐你继续使用该机器(如果一定要使用,请全程有人值守,且保证附近没有可燃物)。官方的说法是(立即停止使用)
It takes 2-3 months to replace the machine or hot bed. My personal suggestion is to use A1. If you have sufficient hands-on ability, you can request BamBu to test the new hot bed and send the accessories to you for replacement. This can also save transportation costs (postage from China to your place is expensive)
Before obtaining the new hot bed, I am not very recommending that you continue to use the machine (if you must use it, please have someone on duty throughout the process and ensure that there are no combustibles nearby). The official statement is (stop using immediately)
I understand peoples genuine concerns but i believe the measures quoted “” above are very adequate , i can also see the misreprentation of short circuit ,
the above image is how my A1 currently sits at a full front bed lengh , its slighty moved to the left but the actual bend near the back is a good few cms past the original protector
我理解人们的真实担忧,但我相信上面引用的措施“”是非常充分的,我也看到了短路的歪曲,
上图是我的 A1 目前处于全前床长度的情况,它稍微向左移动,但靠近背部的实际弯曲比原始保护器好几厘米
Wǒ lǐjiě rénmen de zhēnshí dānyōu, dàn wǒ xiāngxìn shàngmiàn yǐnyòng de cuòshī “” shì fēicháng chōngfèn de, wǒ yě kàn dàole duǎnlù de wāiqū,
shàng tú shì wǒ de A1 mùqián chǔyú quán qián chuáng chángdù de qíngkuàng, tā shāowéi xiàng zuǒ yídòng, dàn kàojìn bèibù de shíjì wānqū bǐ yuánshǐ bǎohù qì hǎojǐ límǐ
关于损坏原因可能每人都有不同的看法。但是至少,这个卡扣不能完全解决问题,这一点咱们都是赞同的
Everyone may have different opinions on the cause of the damage. But at least, this buckle cannot completely solve the problem, which we all agree with
看了你的图,是的,原始状态的弯折情况更好一些。但是我的热床线已经在根部产生了褶皱,所以我为它加上了保护卡扣。
After reading your picture, yes, the bending situation in the original state is better. But my hot bed line has already wrinkled at the root, so I added a protective buckle to it.
How can anyone read this with all the typos? roflmao
我在图里似乎没有发现错别字
I don’t seem to have found any typos in the picture
The loyalMoses email is the only one I have seen, and I have looked a decent amount. The format and syntax of that email match the support responses that are also circulating so I believe it to be authentic. One thing that needs to be considered is that this guy likely contacted Bambu Lab to get information. Someone with his “limited” base (fair by your definition), probably did so via a support ticket rather than some official contact. The structure of the reply makes that plausible. If that is true, the response from support is basically: if you are worried (and the assumption is you are based on the fact that you submitted a ticket) then stop using your A1 immediately. If anyone asks you (unqualified YouTube person) what they should do, tell them to also stop using their A1. That all seems totally reasonable and in line with what has been communicated by Bambu Lab and ensures that they have protected themselves from additional liability. I think the “everyone stop using all A1s now” narrative is based off of a CYA email to one guy from support. Social media has swarmed and generated fear and disinformation off of that.
That is what we in the west call “Satire” it was meant as a joke. :wink:
BamBu官方没有要求我对其他用户作任何提醒,这些建议和提醒是我自发的,我认为这些隐患应该被你们知道和注意。你和我,我们大家都是热爱3D打印的玩家,不应该因为不知道这件事而造成财产甚至人身安全的损失
BamBu officials did not require me to provide any reminders to other users. These suggestions and reminders were spontaneous and I believe these hidden dangers should be known and noted by you. You and I, we are all players who love 3D printing. We should not cause property or even personal safety damage because we are not aware of this matter
Thanks for your provided informations. I’m impressed how fast they can actually reply, usually we see people complaining that they are waiting a couple of days to hear something…
可能是BamBu人手不足吧,他们最近应该忙着测试新配件吧
请注意,这是我的猜测。
Maybe BamBu is understaffed, they should be busy testing new accessories recently
Please note that this is my guess.
您可以试着从BamBu Handy APP上提交工单来询问相关问题,他们应该会较快回复(我猜测)
You can try submitting a work order from the BamBu Handy app to ask related questions, and they should reply quickly ( I guess)
Okay, I understand. Thank you :wink:
BamBu发布了新的通知
BamBu has released a new notification
原文链接:https://mp.weixin.qq.com/s/LM3r_QXI_zQU_iK1mgZV3w
Original link: https://mp.weixin.qq.com/s/LM3r_QXI_zQU_iK1mgZV3w
这个链接是微信链接,我不知道国外是否能够访问,先放这里试试
This link is a WeChat link, I’m not sure if it can be accessed overseas. Let’s try putting it here for now
