I’m trying to cut a rectangular model in to 7 x 3 rectangles. When I cut and check-off stay in orientation, the result is a gap between cut parts. Is the a way to cut and pieces stay where they are, touching each other?
Thanks.
(This was posted bfore I saw other replies related to this.)
If you cut but do not separate, you’ll get walls along the cut line, but the walls of adjacent parts will stick together same as if they were printed as a single object. You need space or the print won’t be separate parts…
