Anyone know how to turn these annoying things off again in Studio version 2.7.1.57? So far everything I have found has not worked, the .conf file rewrite everytime.
Thanks
Thanks
It was doing it in the Beta too, I thought I reported it but now that I checked I didnt.
This is extremely annoying. Does anyone know if this was reported as a bug? This is similar to that silly filament warning before the patched the previous release.
I ended up going back to the previous versionā¦.
You just click on ācollapseā and bambu studio will remember the next time itās run
Thatās a NO, for me. Pops up every time, even after collapsing.
I know, my tips were collapsed so I opened the windows and tried collapse again⦠I canāt close it any more ![]()
It did not work with the beta but worked when I upgraded, I might try that steps again.
btw, I tried many things in config, hints.ini, hints.cereal etc, nothing worked
Same here. Super annoying. I tried manually editing the config but it seems to ignore the setting.
Iāll add my frustration to the heap. config edit did nothing. very annoying closing the same pop ups 100x per day. does bambu even use their own software before afflicting their user base with this slop?
I was able to edit the config in Notepad. Change value for ādaily tipsā from ātrueā to āfalseā. Saved and close Notepad. Restart Bambu Studio (obviously the program should have been closed before editing the config). Daily tips are collapsed now, but still appear bottom rightā¦
Verified this multiple times, closing and reopening Bambu and powering PC on and off.
Not sure why others didnāt have success.
I edited the config file numerous times and it didnāt work.
This Daily Tips popup, again??? This is obscene. This started with the previous release and itās NOT fixed in the latest one. Nothing Iāve tried will hide it for good. What a joke. Back to the older version, again.
itās work, thank you verry much !
Changed my config file some time ago.
You know, show tip from true to false.
Didnāt work for me all the way to 2.7.ā ā or something.
Just updated to 2.8.2.61 and tips now stay collapsed.
Thank you what ever cosmic forces you may be.
