Hi printing community, I have locked my print height and have tried all I can find to fix it with no solution.
please assist me to restore the printing height to 256mm I have the setting under Printer Settings set to 256mm as per the Wiki Knowledge base.
Print-by-object | Bambu Lab Wiki
Are you by layer or object?
By object and items are spaced far enough apart, it appears to be restricting the height on the shortest part
Thanks your info in the Wiki has me on the right track I believe, my ordering of the part print sequence is wrong. print shortest to longest first and then the problem will go away.
