Do I need to setup a printer ‘profile’ (I assume that’s what it’s called) if I want to change the defaults, please?
For example, I would like to use gyroid as an infill and, usually, 3 loops as the wall thickness.
Thanks
Simple as making your changes and saving them.
Then you can select the preset.
Blimey, that was easy! Thank you @JonRaymond
