Bambulab p1p
Bambulab PLA white matt
Basic settings means 220celsius hotend and 65celsius bed temperature and this happend. It wasnt attached to the hotbed at the end of the print. The print didnt turn out that bad and it is usable but the bottom looks this deformed. Do anybody has an ideea why? Thank you
Welcome to the forum.
Read the post below mine as it has solid advice.
Welcome to the forums!
What you are seeing is more than likely due to poor bed adhesion. The number 1 cause of poor bed adhesion is due to the build plate being dirty. It’s pretty easy for the oils from your fingers to transfer to the build plate through normal handling.
Take your build plate and rinse it off under a faucet with hot water and scrub using dish soap. You may need to wash it multiple times, but you should see the water sheet evenly off the plate once cleaned and properly rinsed. Give that a shot and you should see an improvement.
Thank you guys, you were right. God bless you.
