Deleted, Problem Solved
Deleted, Problem Solved, Someone please let me know if there’s another way of deleting a post.
Your changing this drop down correct?
You will need to reslice after changing it.
Deleted, problem solved. Please let me know if there’s another way to delete a post.
Sometimes it’s good to leave up posts so others IF they use search can find solutions :slight_smile:
Yep, understand. Problem is-- I’m not sure how I solved it. :grinning:
Based on the response provided your now deleted post question (please don’t delete content) relates to selecting a plate type for your printer?
If so, mark it as solved using the button under the comment with the solution.
I’m guessing from @JonRaymond.
If you truly can’t remember how you solved the now deleted question content. Add the question back up and someone will help.
Do not start a new post, edit this one.
