For a couple of upcoming projects, I’ve been needing to build some treads that are able to survive a moderate amount of abuse while also being sturdy enough for parts to be attached on the outside. Although I’ve made some progress, I’m stepping back to consider if there’s a best-practice approach.
There seem to be many valid options for this kind of object - has anyone found a particular approach they prefer?
For reference, here are a couple of designs that I’m fond of:
- On the right, these tracks by @MottN print in an orientation where no assembly or joining of the tracks is required. They have a really smooth motion and seem quite stable.
- On the left, this hinge by Emvi 3d prints flat (which may have some benefits for the strength of the ‘pins’) and feel really strong.
Finally, here’s the approach I’ve landed on for my particular application - I believe it’s similar to some common approaches. I needed to print these ‘flat’ (as shown in the photo) to support another part of the design and also needed a strong connection between segments.
The track will print in 2 larger segments and the segments join using a self-tapping screws with a wider central channel that allows for rotation. I had an initial concern that the threads from the screw would be too abrasive on the interior but have seen no issue with this even with significant use (and disassembly for inspection).
In this cross-section you can see that the connection between segments uses a cone shape. I had to tweak the dimensions but it has been stronger than I expected - far more than my requirements.
