Developer mode
when you select the nozzle type there is the issue that comes : bambu slicer printing high temperature material (petg-cf material) with stainless steel may cause nozzle damage please fix the error above, otherwise printing cannot continue … even if i select harden steel nozzle it still wont let me print and gives me this error. I selected the a1 mini. thank you
Perhaps this is because it isn’t recommended to print CF filament with the A1 Mini?
well… i bought the harden steel nozzle in order to do so
nope i found it after 1 $##@$!@% hour… good lord! and I own 4 a1 … 5 x1c lol and build lots of printer… there is nowhere that specify that you need to go on the printer to manually change it and specify it… very anoying
PLACF worked fine on my Mini with the hardened 0.4mm, I can’t remember if there was a warning (I also use off brand). Either use the external and don’t tell or tape the tag off with foil (if that works?)
