Do you know where can I correct the “height” of printed items - Z axis?
I set the other x y dimensions using flow rate and I have no problems with accuracy up to 0.0_
If it’s obvious, then I apologize for the question but I am a newbie.
Thanks for the suggestion, but this compensation factor is really meant for individual parts to tweak hole size/fit without changing the original part design.
I think what the OP is looking for is a steps/mm adjustment that would apply to the printer movement itself. I have found that on my other printers I need to adjust this separately for X, Y, and Z axes to get the the precision dialed in precisely.
Is there any way to do this on the X1C?
