Dimensions: Bambu Lab X1, X1-Carbon
Since I have unfortunately nowhere found the information about the dimensions including all attached components, I just ask you.
I need the total height (including Automatic Material System (AMS) )as well as the total width and the total depth with touch display.
The reason is that the planned installation site size is limited.
Thank you for your support.
Printer:
AMS:
@Flashy_DE Can out confirm that the printer dimensions are with the touchscreen in front? And I saw that some components needs to be attached also on to the back of the printer. Are those also included in the Dimensions Data?
Can some one please confirm that dimensions in in assembled state. This would be great.
Thanks.
you need at least a high of 70cm if you put your ams on top and a length of 55cm. because of the display and back spool holder
Thanks for sharing, so I think you’re describing a footprint (with AMS) of 389 x 550 x 700 - this is super useful to me as I’m also trying to find space for the machine ahead of purchase!
Can anyone confirm the actual “foot” print where the feet would make contact with bottom surface (I suspect it’s narrower than the actual width and length of the full enclosure. I ask because I want to use a slightly smaller table to fit this into a tight space. Much appreciated!
The footprint on the outside of the feet is 370mm square. The feet have a diameter of approx. 25 mm
Don’t forget the filament purge that is ejected out the chute in the back of the printer. You need some way to handle that – minimally you need enough open space behind the printer for the filament purge pieces to exit. Then you need something to capture them. If you are using a stand that is the size of the printer, or smaller, then your purge pieces are headed for the floor.
Also, don’t forget the AMS lid raises up when it opens so you need clearance for that.
With the catch bin for the purge chute the “working volume” of my X1C is 49cm wide x 61cm deep x 84cm tall (AMS open).
