Dimensions of A1 mini with AMS lite
Hi! I made a JPG of dimensions including AMS lite, I put here because can be useful for someone :slight_smile:
Please to confirm, can you measure the width of the printer (without AMS lite), is it 38cm? And what is the width of the part that sits on the table of only the printer?
Thank you very much!
Thank you for dimensions. I have an outstanding idea for housing for my awaited A1 mini :smile: It will be hilarious. Probably the only one of its kind in the world. Regarding your question on Bambu Lab A1 mini - Technical Specifications it says even less: 347mm width.
Here are my dimensions. Essentially 22” wide x 22” high. Sorry, too new to post pics.
Its possible to unmount “poop dispenser” I have only 37cm space :frowning:
From the right farthest endpoint to the left farthest end point I got 13.5 inches which converts to 34cm. That’s just the x - axis of the front.
You can turn off the flow calibration which is also known as the purging feature. I turned that off and no purging, its a nice little setting.
Thanks👍…just what I was looking for. very helpful!
can you please confirm if table with 40cm size for depth (y axis) is enough for this printer. Thank you
I did the same but I wonder if I should turn it on from time to time? Is it necessary?
Thank you that was so helpful! I used your drawing to figure out roughly the side of the base only as I need it to fit on top f a round table, some parts will stick out but no problem :slight_smile: One question this measurements don’t account for the spools right? Im auming since they are not shown on the image, just checking! Thanks!
I’m currently using a table that’s 55 cm wide, on which the printer and AMS sits just about comfortable with the printer sticking out on the left side. That’s as small as I’d say is comfortable. The actual minimum space you would need is probably about 65 cm wide.
Thanks for this. It’s exactly what I was looking for.
I don’t yet have my AI mini Combo, but already planning where I am going to house it. I had already been planning on buying 2 Ikea BESTA storage shelves, and am now planning that each shelf has an open middle section which the printer and AMS lite can live.
Each shelf in the BESTA storage unit will be 60cm Wide X 41.4cm Depth X either 62cm Height or 49cm Height.
Which height would you recommend?
Also, how far apart can you keep the AMS lite from the main unit? As I would like to have each within it’s own shelf.
| A1 | |AMS|
^ Best I can draw without uploading images
