Dimensions of the hex wrench that came with P1S?
I lost the bigger and longer wrench (is it 2mm?) that came with the printer from the factory. Could someone please be so kind as to help to measure the hex size, the long edge and the short edge of the wrench? I liked it very much and feel the size is perfect, and also I have a toolbox that i printed which just nicely fits it.
Bambu doesnt sell it, so I guess I’ll have to look from aliexpress or something.
Thanks in advance!
Looks like 130mm for the long side and 20mm for the short side. The long one is the 2mm. You can’t go wrong with WERA as a replacement but probably not in that exact length.
If the sides are too long, they can be shortened. And if they are a bit shorter, they may still fit the toolbox.
The factory wrenches are made of soft metal and should be replaced anyway. The small one in particular is only good for 2 or 3 uses before being reground and the worn ball end can slip, damaging the screws
Thank you so much guys!!!
