I’m probably just going to keep my filament grouped but not segregated to a cabinet. I am pretty sure I’ll just be setting both cabinets to 10% and leaving them there. My reasoning is I’m already drying PLA and PETG to below 10% anyway and haven’t had any issues.
Down side will be more cycles on the regenerator by running at low humidity, but might not be too bad. Swapping spools back in from my AMS units will probably be carrying some amount of water into the cabinet depending on AMS desiccant.
Now with a 10 hour battery life on an optional internal 500mAh LiPo battery that acts as a UPS and makes for a very portable monitor. If installed, battery recharges automatically from USB whenever plugged in. On/off slide switch is at upper left. No soldering, audible button feedback and optional alarm, real-time coarse humidity indication with the LED bargraph, configurable time axis, switchable temperature units, maximum or average logging, autoscaling y-axis, auto-dimming bar graph LEDs, and configurable bar graph setpoints. About $42 including SHT41 sensor, not including battery.
I ordered some VOC sensors to make a version that reads and graphs organics in the ambient air. The code changes are trivial so it’s almost free. I think that will be interesting to see when VOCs actually calm down after a print. I’m modifying the housing to include the sensor so it will be sampling the air immediately around the display.
Are you in the US? Reason I ask is it’s really a lot easier to build and program than it seems from the directions. I’m verbose but try to head off problems people might have but the steps are actually pretty easy.
I’m trying not to do that kind of thing if at all possible. Contact by DM if you’re in a bind though and do really want one.
If it’s just the programming aspect I can try doing a video but those screen grabs in the description pretty well cover it. The problem is for whatever reason Adafruit is shipping them (or was) without the bootloader. That forces the web page install but it does work well especially if you are using Chrome on Windows.
I’ve programmed the MagTags a few times and it really goes pretty quick and is easy. It just looks hard when reading the steps. The real beauty is once you get the bootloader set up, it behaves just like a USB drive and programming is just dragging and dropping files on the drive icon. It’s a really ingenious way to bring these devices up and really couldn’t be simpler.
And I did a lot of print revisions to get the fits of everything right. I threw away as many or more body shells as are in that group photo.
What I’m really curious about is how people like the way it works. I put a lot of effort into that and the code got revised a lot while bringing them up to streamline things. There are limitations imposed by the e-paper display. I would have loved an interactive menu but that gets clumsy with 5 second refreshes. That’s why changing some defaults requires manually editing the code (LED RH thresholds, the alarm level, x-axis time scale) but that’s trivial stuff (editing a text file) and the settings are commented in the code to give a roadmap on how to set them.
