Do there exist smooth PEI build plates that aren't made from stickers?
If so, I haven’t found any–at least none that are advertised as such. In contrast, non-sticker textured PEI build plates do exist (e.g. the ones made by Bambulabs).
The reason I ask is that I often read about PEI stickers whose adhesive has bubbled under use, rendering the build plate no longer flat. For that reason, if the PEI could somehow be bonded directly to the metal, as is done with the textured plates, it would eliminate that failure mode.
You could check the shops of Energetic or Super 3D within Aliexpress. They have some nice ones.
I think, the Energetic smooth plates from AliExpress are far superior to the stickers from Bambulab and you get a complete double sided plate for a little more than the sticker from BambuLab.
Two caveats:
1.) the energetic smooth plate has no QR code (only their black textured pro plate has). I solved that with a label printer, e.g. a dymo or brother.
2.) The PEI surface has rough edges, potentially scraping the magnetic bed over time. Going around the edge with a round piece of steel using some pressure solved that for me.
PETG sticks a little bit too good even after cooling, but I guess that is the nature of PETG on smooth surfaces.
