Does H2S print much faster than H2D?
Hi folks,
Im weighing the idea of a 2nd printer. I mostly print high temp materials in single colour.
I read previously that the H2Ds speed is constrained because of the weight of the toolhead. Can the H2S print a lot faster? (Assuming flow rate etc. is dialled in)
Thanks
It depends on what you define as restricted. The larger weight of the tool head might limit the acceleration, but the H2D and H2S both have the same maximum speed and acceleration.
When printing engineering materials, the maximum speed of 1.000mm/s won’t be the issue. Acceleration for both is 20.000mm2/s
The only gain is coming from the high speeds on traverse motions.
If you want the fastest, you can consider the H3C because the max speed is 1.400mm/s and acceleration is 25.000mm2/s.
Additionally, combining a large nozzle for infills with a smaller one for the outer boundary gives you an additional speed benefit over the H2S.
The H2D will get multi-size nozzle support by the end of the month.
