Does "Send" option only work on LAN Connection printers
I’m trying to just send a sliced file to the printer to the SD card for later printing.
When I choose “Send” from the slicer I get an error "LAN Connection Failed (Sending print file) and it’s a dialog about having everything set up for a LAN Connection.
Am I missing something?
“Send” should work in both Cloud and LAN mode.
You will need to disable LAN mode if you are printing via the cloud.
LAN Only is set to “Off” on the target printer. I print to this printer using Bambu Cloud.
That’s odd. Semi related question, have you formatted the SD card in the printer?
Yes, SD was formatted and works fine.
The problem “resolved” itself.
Even though LAN Only was off, I turned it on, refreshed/reset the access code.
Then I turned off LAN Only.
On WiFi I did a network connection test - all was well.
Now on BS it was disconnected from the printer. So I choose the printer and has to log into it via the cloud again.
After all this is could perfectly send to the SD card via the cloud connection.
