Does the H2D still make sense as upgrade from a H2S
Does in 2026 the H2D still make sense to buy?
I have a H2S and miss the possibility of using different filament for interface alyers to have nicht surfaces above overhangs. And the second point is that I could reuse all the nozzles and plates that I used from my H2S. Or is it better to buy a H3C?
Yes, absolutely. The fact that it’s about to get dual size nozzle capability makes it even more useful than it was at launch.
That really depends on your future requirements.
When you only seek to print one material, with a separate support interface material, the H2D is sufficient, and is cheaper than the H3C.
As you mention yourself, you can reuse almost all your accessories.
Might you have a laser version, then also the laser can be reused on the H2D. That capability will get lost on the H3C.
I am currently on the H2D, and for most of my work the 2 nozzles are enough, but I sometimes have prints with 4-5 filaments, and then the AMS really gets busy and printing times increase substantially.
So I am interested in the H3C also, but currently not in a hurry. I am still undecisive if I would want to keep my H2D as it has a 10W laser, that I rather not give up. I have space for both though.
Decision is not made atm. Might wait for the P3C, for the multicolor stuff. Or for the H3C to drop price a bit.
I also made some multicolor lightboxes, but only a few layers which does not really count.
The only real advantage for now is the possibility to print TPU very well. That*s bad on the H2S and I think not better on the H2D?
Correct!
I am therefore curious what the P3C specs will be. If it can do proper TPU and multicolor, that would be a great addition to my H2D.
Many considerations to make for the H2D, H3C or maybe the upcoming P3C.
