Don’t Embedded Magnet(s) Interfere with the Print Head’s Movement?
Some people recommend that, in order to embed one or more magnets in printed objects, pause the printing, insert the magnet(s) into the cavity(ies) that was formed for it (them) and then resume printing. The only warning I’ve seen about this procedure is to make sure no magnet protrude out of its cavity, potentially blocking the print head’s path.
But what about the case in which the nozzle or hot-end is ferromagnetic? Wouldn’t the embedded magnet (s) attract it as it moves nearby, possibly altering its path off course?
I don’t think that’s much of an issue, the magnets most likely aren’t strong enough. You can push against the toolhead while it’s moving and it will still just keep moving, and if you do manage to stop it you get an error message and it pauses the print.
Another risk is that the magnet will pull out of the recess.
So, a dab of CA glue fixes the issue.
You are correct that magnets can get picked up or flipped out of the hole, by the nozzle passing over. Typically, the magnet pockets are made snug enough that the magnet is held in well enough that the nozzle won’t pick it up. But if it’s not snug, use a small drop of CA glue to anchor them in.
Unless you are using a very large magnet, that will nit be an issue.
Yeah, I would be more worried about magnets pulling off the toolhead cover.
Is there a different between the stainless and the hardend nozzles?
0.4 - I believe one is carbon steel, the other stainless.
Before you drop the magnet in, put a drop of super glue in the hole. Be fast because its gonna dry fast. If ypure worried about an impact. Like from the fan shifting the magnet or whatever
Edit: @Rmedias and @Crabnabit already said this. muh bad
Thgis stupidest thing i did was try to pause a print to fill a hollow print with sand to weight it before the printer sealed the top. Of course, the part cooling fan blew it everywhere. I don;t know what i was even thinking (probably wasn’t thinking, I giess).
I saw a clip like this on youtube, they ended up using clay instead.
I would dab a bit of accelerant into the seam around the magnet in this case as CA glue won’t cure fast in some plastics. Use a fine tipped paint brush and the thin accelerant will seep in to the well due to capillary forces.
But, I agree, CA glue will solve this problem.
It sounds like you were printing a tape dispenser. you can do that, but you have to turn the fans off until a full layer has printed to seal the sand in. For some reason the models that mention sand as a ballast forget to mention the fan.
Just had this exact issue I believe. I know this is an old thread, but found it while searching to see if anyone had experienced the same before. Wasn’t sure if I was going crazy or not!
I do a bunch of printing with embedded magnets, normally with small disc magnets. They’re never an issue, just had to dial in the hole tolerances. Recently I started a new project where I needed a stronger magnet, and based on the nature of the part and print orientation I’m using a 60mm bar magnet and putting it in sideways. On my H2D with the tungsten carbide nozzle it printed great, dialed in the tolerances and it’s good to go. On my X1C however, it keeps failing after I embed the magnet and resume. Stays embedded nice, but the whole print layer shifts over about a whole inch.
At first I thought I was crazy, maybe I bumped the print head. Then the second time there was some purge chute build up, so maybe it could’ve hit that. But now I’m starting to think the magnetic attraction is too much for it and it must be pulling the print head off course.
If this is the case, does anyone have any recommendations for a replacement nozzle for the X1C that’s not ferrous?
stainless should be safe, as usually amagnetic (this is a way to check stainless agains standard steel)
Apologies, I should’ve included that I’m also using CF filament, so I didn’t think the stainless would be a could long term solution in terms of its wear and tear. So I need to try and find something as strong as the hardened steel or tungsten carbide, but for the X1C.
