Door and screen removal
In order to integrate the X1 in an existing shelf I would like to know if it is possible to remove the door and connect the screen externally. I mean put it for instance 50 cm away from its standard place.
Thanks
Yes the door can be removed. It’s just a few screws. I’m sure Bambu has a video on it. Look up the on wiki or YouTube.
No, you cannot relocate the screen. Not unless you have the skills and equipment to make a ribbon cable extension to lengthen the factory screen ribbon cable
