Dots, Commas, Underscores in STL and Folder Names
Uhl, have you tried using a file renamer? You might find that this is just the workaround that you are looking for because you will be able to substitute the periods with another character… problem solved! And with a good renamer you can batch rename. I use a renamer all the time… and I then don’t have to ask someone else to change how they work.
