Downloading seperate .stl's
Hi all, downloaded a 4 plate file (big ghost) Bambustudio tells me the model needs fixing so I want to drop it into formware for repair.
Only problem is i cant access the individual .stl’s from the ‘download and open’ file given to me by makerworld!
How do I extract them seperately?
Open the 3MF in Bambu Studio…click on File, Export, Export all objects as STL’s.
Thank you Lion, thats sorted that so far. No when I try to load the .STL it says 50Mb limit reduce mesh, file is 67Mb.
Can i reduce mesh in Bambu studio do you know?
I don’t know what that means.
You can right click on a model and do “simplify model”.
Most of the time models don’t really need repair even if it says so since it does it automatically, check the slicer output.
This right there ^^^
Keep in mind that Simplify will remove triangles so the model “could” lose some detail. I’ve had to do it to statue models before, but the loss of detail wasn’t noticeable to me. I’m sure there’s some but it didn’t reduce the aesthetics.
If you simplify the model, new errors may occur in the mesh.
