Downloads from parametric models "Customize" button do not appear to be counted
Hello everyone,
First, I would like to say that I may be wrong about this but I don’t think so.
I have published a few parametric models on MakerWorld and I noticed something that seems unfair compared to non-parametric models: when a user customizes a model and downloads the generated customized version, the number of downloads for the model does not increase. This means that many downloads for parametric models are not actually counted.
Can anyone shed some light on this ?
Thank you !
This has been discussed extensively previously.
As I remember that discussion, regular models earn the creator two points.
Because parametric models have the potential to generate far more downloads, and are easier to create versus many iterations across all possible configurations, creators are getting and easy pathway to a lot of points, so they will get one point per print, rather than two.
Are you sure about this ? Can you provide some links to other discussions ? If non-parametric models are rewarded more than parametric models it would be so easy for me to simply provide multiple predefined versions and earn more points, instead of taking the effort to publish the customizer and make the models much more useful. It seems completely wrong to me for non-parametric models to be favored. But I would like to know if this is really true so I can change my approach in the future.
Merci pour ce post. Je suis aussi affecté et j’ai une preuve flagrante.
Regardez mon modèle “Nom 3D personnalisable” sur Makerworld:
  • 159 downloads :white_check_mark:
  • 0 makes :cross_mark:
  • 772 clics “Personnaliser” :police_car_light:
C’est mathématiquement impossible.
Si 159 personnes téléchargent un modèle, il est statistiquement certain qu’au moins quelques-unes vont l’imprimer et le reporter.
Mais 0 makes + 772 personnalisations = le bug est avéré de manière irréfutable.
ET C’EST ENCORE PIRE SUR L’APPLI:
Sur le site Makerworld, au moins on VOIT les clics “Personnaliser” (772).
Sur l’appli BambuLab (où 70% des utilisateurs se trouvent), on ne voit même pas les customisations/makes déjà faits. Les gens customisent, impriment… et rien n’apparaît nulle part.
Conséquence pour les creators:
  • Sur le site: on voit des clics mais 0 stats comptabilisées
  • Sur l’appli: les customisations ne remontent MÊME PAS
  • Résultat: 1000 utilisateurs qui impriment = zéro visibilité, zéro impact, modèle invisible
@BambuLab - Ce n’est plus une suspicion. C’est un double bug produit:
  1. Stats des personnalisations non comptabilisées (site + appli)
  2. Customisations invisibles sur l’appli mobile
Pouvez-vous confirmer les bugs et donner un ETA pour les fixes?
Les creators méritent des stats fiables pour prendre des décisions.
